Truetone 724 cabinet makeover
The red on those dials really washes out over time. If I were going to keep the radio? I might let it slide for now. If you are going to sell then yeah I might replace dialscale..one less thing for a buyer to pick at.
Both places sell the replacements/radiolaguy and radiodaze.
I havent had to replace any yet for the model but in both places the coloring of their replacements looks off to my eyes.
Check with guys that have actually purchased replacements and see if that brown outer band is more accurate than the pictures suggest. The ones made for Detrola look right colorwise but the Truetones dont. Maybe a function of the photography/
http://www.radiodaze.com/truetone-d696-d724-727-3950/
http://www.radiodaze.com/detrola-model-1...m-ds-a677/
(11-15-2015, 10:15 AM)JimZ Wrote:  The red on those dials really washes out over time.  If I were going to keep the radio?  I might let it slide for now.  If you are going to sell then yeah I might replace dialscale..one less thing for a buyer to pick at.
Thanks for the tip, i like radio daze better , but will check around from others on accuracy
I asked Paul Sanders Fred. He told me the one radiolaguy did is dead nuts to original..it was copied from one Paul sent along to him.
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 779 online users. [Complete List]
» 2 Member(s) | 777 Guest(s)
