610 schematic parts layout for filter circuit?
http://www.nostalgiaair.org/pagesbymodel...013797.pdf
What I see in the set and what I see on the parts layout don't seem to match here. It looks to me like filters C41, C55, C56 are switched on the parts layout. In fact, there seem to be several small part number errors on the part list as well.
It looks to me like the parts layout labels C41 as C54, C54 as C56, and C56 as C41.
On the set, the 8uf cap that has its negative side connected to the large end of R57 and the CT of the HV secondary also has the cardboard insulator and a 10K resistor connecting it to the electrolytic above it which should be the 16uf cap (part C41). The one on the position labeled as C56 has connections to the output transformer and C47.
On the parts layout, you can see the cap labeled as C41 has three rings on the outside which would indicate it is the one with the cardboard insulator, right?
Likely, this is documented somewhere, but I'm not finding it. Unless I hear otherwise from you Philco experts, I'm going with the layout I find in the set and following the schematic.
Here is a photo of what I see; that red wire going across the photo between the green and red resistors connects the e-cap on the left top to the CT and large end of the wire wound resistor:
The broken resistor is grey with silver at each end?
Charlie in San Antonio
PN 40 25K 2W
http://philcoradio.com/phorum/showthread.php?tid=215  I was just working on a 610 a few months back and I recall there were errors in the schematic and if memory is good they are documented in the changes.zip file (above) that Ron generated.  If you order a set of docs from Chuck, it will be in there also.
Ah, yes! Bulliten note number 217. There it is. Thanks.
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
There are currently 879 online users. [Complete List]
» 2 Member(s) | 877 Guest(s)
