Planning on restoring a Model 46-1201 (Build 125) Bing Crosby in a few months, and am trying to locate a few parts beforehand.  I found on another post the part number for a replacement Idler Wheel for the M-7 turntable.  However, has anyone found a suitable replacement for the 2 "sleeves" on the guide rollers?  Mine appear quite worn, and have seen better days. If there was a replacement available, I'd like to swap those out.  I also have info from other posts regarding the needle assembly in case I need to change cartridges.  Any other issues with these units that I should be aware of ahead of time other than the standard replacement of caps and any resistors as needed?  Thanks!
