Padded Feet for Philco 38-15
Ron,
1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Thank you.
David G. Woodward
WildDog Wrote:1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
If these are the same feet as Philco used on their cathedrals and tombstones (and I suspect they are), these are no longer being manufactured (as far as I know). Many cabinet refinishers, such as Barry Jones, use small circular stick-on felt pads instead which do a better job of protecting the furniture they sit on top of.
Quote:2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Sorry, can't help you on the back. I suggest you put an ad in the Philco Wanted section.
As for the cloth, that particular pattern is not being reproduced. A similar pattern is #8 from Radio Grille Cloth Headquarters.
http://www.grillecloth.com/
The 40-124 in my site's Gallery does not have the correct cloth for this reason. The correct pattern may be seen on the 40-90CB:
http://www.philcoradio.com/gallery/1940a.htm#e
This type of glide is available. A little bulky, though.
http://www.floorsaverglide.com/catalog/i...p?cPath=27
http://www.allglides.com/feltpads.html
[Image: http://www.floorsaverglide.com/catalog/i...nailon.jpg]
I use a nail-on plastic type from McMaster-Carr.
[Image: http://www.mcmaster.com/catalog/116/gfx/...13tp2s.gif]
Thank you all for your help.
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1161 online users. [Complete List]
» 2 Member(s) | 1159 Guest(s)
