Philco 40-155
Have been unable to locate the correct schematic for this.  All the schematics I find show a 7J7 for the detector/oscillator, mine has a 6K8. The chassis is stamped  40-155, code  121 and the schematic is similar except for condenser 6 and 22 which are a different value listed that what is in this radio.  Performance seems about the same compared to the Philco 39-25 that I restored earlier.  The 40-155 uses a 1232 (7G7) for a r.f. amplifier and an additional 41 for push pull output so I really expected better sound and better reception; I even replicated the built in antenna on the 40-155.  Both of the radio's came without speakers so I installed the same type of  pm speaker in both, would the original speaker make a difference in sound quality?
Welcome to the Phorum, Roger. Here is the service data for your radio. See the production dhanges listed on page 2. Take care, Gary
Gary, thank you for the instant response! Think I'm missing something here, can't seem to find the service data that you posted.
Sorry Roger, forgot to add it. It's all found at the bottom of the page in the Philco Radio Library.
https://philcoradio.com/library/index.ph...year-book/
Take care, Gary
Hi Roger,
First off, Welcome to the Philco Phorum!  Secondly, apologies in advance for the length of this post.
I am sure that Gary will answer you the next time he is on line.  On the bottom right of the page, you will see the Avatars(?) of those members who are currently on line.
The following link is from the Philco Library on this Phorum and shows the version with the 7J7 Pentagrid Convertor.  Triode-Heptode First Detector.  (Edited 01/14/2025 for Correction to description of the 7J7)   I must apologize that in this post, I described the 7J7 as a pentagrid convertor based on my interpretation of the schematic in the Philco library.  After consulting the RCA Receiving Tube Manual, I note that the 7J7 is a triode-heptode (a heptode being a tube with a cathode, plate and 5 grids) tube, similar in function to the 6J8 other than the base design and pinouts.  The 6K8, a triode-hexode (a hexode being a tube with a cathode, plate and 4 grids) while different in design does the same function.   The difference between the triode-hexode or triode-heptode and the Pentagrid or autodyne detectors is that the triode-heptode or triode-hexode provides a "separate electron path" (sharing only the cathode) for the oscillator and mixer with the advantages of having both "tubes" in the same envelope.  The Pentagrid Convertor (Heptode) uses a "grid - plate" as the oscillator plate, but the "electron paths" of the oscillator and mixer are the same, passing through all grids.
Part48-Philco 1940 RMS Year Book.pdf
Now this is where it gets interesting!
The same document states that there are certain runs with a 6J8 Octal tube replacing the 7J7.  Per the Radiomuseum website, The 6J8 is supposedly a Russian version of a 6K7 remote cutoff pentode, hardly the tube one would want to use as a convertor.  However, Radiomuseum also lists a 6J8 Triode Heptode, where the triode is used as an oscillator and the heptode section is used as a mixer.  This triode oscillator / heptode mixer configuration usually works better at high frequencies than the typical pentagrid convertor.  Remember, that in the late 1930s to 1960s or later, shortwave was to many people what the internet is today.  Shortwave was the window to news (true or propaganda) of the developing conflicts that culminated in WWII, and for many immigrants, news of the land that they left. (Edited 01/14/2025- The fact that the 7J7 and 6J8 are both triode-heptodes with similar construction and function other than basing, and the fact that Philco does not give tube pinouts on the schematic may be the reason why a separate schematic for sets using the 6J8 was not published.
The next issue is that your radio has a 6K8, which is a triode hexode, not a triode heptode.  These are not the same tube.  Is the tube location sticker still in your radio?  Does it state 7J7, 6J8 or 6K8?
To further complicate things, there is no insert in the Philco Service Document for your radio showing the 6J8 circuit.
The following may help:
Attached below are 2 pages from Radiomuseum describing the 6J8 and the 6K8 and showing typical oscillator mixer circuits with tube "pinouts":
Attached below is a link to the Philco 41-722 which uses the 6J8 Triode Hexode:
Part67-Philco 1941 RMS Year Book.pdf
Attached is an "Emergency Tube Substitution Guide published by RCA during WWII.  (New radio and replacement part production stopped in 1942 to build the electronics that were required by the US Military.)  The manual does not show that a 6K8 can replace a 6J8.  Both tubes are listed.
Now, for the poor sound issue:
Are you dealing with a distortion issue?  The fact that you have a 6K8 instead of a 6J8 may be an issue.
I am a believer in "divide and conquer troubleshooting.  In addition, I like to add "aux inputs" to my radios so that I can pipe music from an MP3, computer, etc., a great way to get "old time" radio to play from your "old time radio" (pardon the pun).  It also helps in the diagnosis of where the distortion comes from.  The amplifier section of this radio should sound rather clean.  Not Fisher, Scott or Marantz clean, but clean.  The best place to "inject" an outside signal is at the junction of the detector and the Volume control.  If you are interested, I will do a diagram.  Any modern speaker is likely better than the original.  However, there are 2 issues that must be dealt with:
  • Correct voice col impedance for the transformer in use
  • Correct resistor or choke in place of the field coil (and likely the necessity tto increase the capacity of the filter caps).
Do recap the radio and check all resistors.  For this and other radios, Philco has a rather novel method of getting the inverted signal for the second Pentode in the Push Pull Circuit.  Note that there is no Phase Invertor Stage.  Note the 3900 Ohm resistor between B+ and the screen of one of the 41s.  Note the capacitor between the screen of that 41 and the grid of the other 41.  That is how the inverse phase needed for the second pentode in the push pull output is generated.  It is critical that all caps and resistors in this section of the circuit be exact (within stated tolerances) and in good shape.
Again, sorry for the length of this.  Hope it helps!
Thank you for the thorough answer and explaination!
The radio sticker on the inside of the cabinet states 7J7, seems like it's likely that someone put a different chassis in the cabinet. I was wrong saying that the radio had a 6K8 installed, it has a 6K7 installed. Would performance be better if I installed a 7j7, or would the difference be slight?
I did thoroughly go through the amplifier section replacing the resistors and capacitors since the values of the resistors had drifted more than 20%. To compensate for a pm speaker I installed a 1k ohm resister and bumped the second capacitor to 47K'. Also added bluetooth but I injected the signal to the volume control and ground. Would be interested in how you would connect.
So Philco didn't release a schematic showing the 6k7 installed instead of the 7j7?
Hi Roger,
It sounds like you installed the Bluetooth in the correct place.  Short answer to how I would install the "aux input" (Bluetooth, phono, etc.) is to break the connection between capacitor 38 and volume control 41.  Use a SPDT switch to select input (radio or Bluetooth).  This is similar to what Philco does with radio-phono combinations.  They may shut off B+ to the radio section or short the detector output to ground to prevent bleed-through of the radio signal when listening to the aux input but this is not always necessary.  Does the sound with Bluetooth fail to meet your expectations or is the issue only with the radio?
I also must apologize that in my previous post, I described the 7J7 as a pentagrid convertor based on my interpretation of the schematic in the Philco library.  After consulting the RCA Receiving Tube Manual, I note that the 7J7 is a triode-heptode (a heptode being a tube with a cathode, plate and 5 grids) tube, similar in function to the 6J8 other than the base design and pinouts.  The 6K8, a triode-hexode (a hexode being a tube with a cathode, plate and 4 grids) while different in design does the same function.   The difference between the triode-hexode or triode-heptode and the Pentagrid or autodyne detectors is that the triode-heptode or triode-hexode provides a "separate electron path" (sharing only the cathode) for the oscillator and mixer with the advantages of having both "tubes" in the same envelope.  The Pentagrid Convertor (Heptode) uses a "grid - plate" as the oscillator plate, but the "electron paths" of the oscillator and mixer are the same, passing through all grids.
Does the radio even work with the 6K7 as the convertor (the stage that converts whatever the chosen frequency to the IF frequency)?  The 6K7 is a "remote cutoff" pentode, used for RF and IF amplifiers, and is rarely used as a convertor (sometimes referred to as the 1st detector or oscillator mixer).  The 6K7 may be used as a mixer when there is a separate oscillator tube, as used in the first generation of superheterodyne radios.  The "sharp cutoff" 6J7 was used by Philco on 37-84 "entry level" superheterodyne as an "autodyne" oscillator-mixer 1st detector.  This "Autodyne" detector is generally unstable and is not used at high shortwave frequencies. Ever since the introduction of the 2A7, the first "pentagrid" (heptode) convertor tube designed specifically as a combined oscillator-mixer.  The heptode (pentagrid convertor) was the most popular form of convertor (Oscillator - Mixer or 1st Detector) used in superheterodyne radios.  Other popular Pentagrid Convertors include the 6A7, 6A8, 6SA7, 6BE6 and their 12V equivalents.
One of the Experts or maybe Ron Ramirez coined the term "Franken-Philco" (or is it "Phranken-Philco"), changes made by Philco but not documented.  The service notes for the 40-150 and 40-155 from the 1940 Philco Yearbook discuss the substitution of the 7A7 Pentagrid Convertor with the 6J7 but did not publish the circuit.  No documentation on this chassis or any Philco chassis of this era having a push-pull output and diode 2nd detector that I have found either in the Philco Library or the Nostalgia Air Website uses a 6K7 either as an oscillator-mixer or as a mixer using a separate oscillator tube.
Note also, that this radio was built between 1939 and 1940.  From 1942 to 1946, manufacturing of electronic devices and parts were reserved for the military and parts or tubes for civilian use were scarce, often requiring substitution of a failed tube with either one not ordinarily used bty the manufacturer or a less than ideal substitution which negatively affects the performance of the set.
In the previous post, I posted the circuit diagram of the radio, and the tube pinouts for the 6J8 and 6K8 tubes.  Below, I provide the pinouts and description of the 6J7, 6K7, 7G7/1232, 6A8, 6J8 and 7J7 tubes from the RCA Receiving Tube Manual version RC14, ca 1940.
The best advice that I can give about sorting this issue out is to:
  • Please list all the tubes actually installed in this radio.  This will help sort out whether this chassis is correct for the cabinet, a substitution. by a similar or a total oddball user-built Phranken-Philco
  • To the best of your ability by wire tracing, please confirm that the socket occupied by the 6K7 is actually the convertor socket.
  • To the best of your ability, determine if the socket was replaced or rewired.  If all sockets except the convertor socket are riveted to the chassis but the convertor socket is attached by screws, it was likely replaced.  If the soldering and wiring "job" does not match the rest of the radio in technique and quality, then the socket was likely replaced or rewired.
Thank you for patiently writing a thorough answer.
The radio indeed did come with a 6J7 instead of a 7J7, the tube socket is riveted in. Would performance increase rewiring the radio with a 7J7? Listed tubes are 1232 although it has a 7G7, 6K7, 7B7, 7A6, 7C6, 2-41's and a 84.
I replaced the 3900 ohm resistor with a 4.7K, sounds like I should get the value back to 3900 ohms.
Hi Roger,
Sorry, I did not get around to posting Tube Diagrams in the previous post. The RMA Tube numbering standard is very confusing as there are numbers that sound similar but are very different.
The 7G7 and 1232 are the same tube, a high mu "sharp cutoff" pentode used as a TV video amplifier in early 1940s TVs. So the 7G7 is correct for your set, even though the tube diagram calls for a 1232 The 6J7 is also a sharp cutoff pentode. The 6K7 is a "remote cutoff" or "variable mu" pentode. The 6J7 and 6K7 have the same pinouts (Basing Diagram) but are used for different purposes. The 6K7 is usually used as an RF and IF amp in sets having AVC (Automatic Volume Control) controlling the tube. The 6J7 is used as an audio amplifier, Biased detector or "Cathodyne" 1st Detector (Oscillator / Mixer). The 6K7 is rarely used as a Cathodyne Oscillator / Mixer. The 6J8 and 7J7 are Triode / Heptode tubes used as an Oscillator / Mixer. The tubes have the same characteristics but different bases and pinouts. The RCA Emergency Tube Replacement Guide does show the 6J8 and 7J7 to be replacements for each other, however, the socket and wiring must be changed.
The bottom line is that if the tube diagram placed in the cabinet has 6K7 printed instead of handwritten as the 1st detector, convertor or oscillator / mixer, then you have a factory Phranken-Philco.
I cannot find any diagram or documentation for this model showing either a 6J7 or 6K7 being used as a 1st detector. THe only tubes documented as 1st detector for this model are either the 7J7 or 6J8.
Attached below is a diagram for the 37-84, showing a 6J7 used as a 1st detector. Look to see if there is a coil between the cathode (pin 8) of the 6K7 and a resistor with bypass capacitor, the other end of which goes to chassis ground. If so, then you do, in fact have a cathodyne 1st detector. Otherwise, this thing shouldn't be working.
Hopefully this all helps. Thanks for reading it all. I am a frustrated wannabe teacher (or am i a frustrating wannabe teacher?)
What we all do here is useful, not only to preserve history but also in providing technical support, I am forced to think and reason. This (hopefully) keeps the ol' grey matter percolating.
My only hope is that younger folks take up this hobby for the same reasons.
Doing more research a Philco 40-165 uses a 6J8 instead of a 7J7. I bet that is what is intended for this 40-155, the 6J7 works but just for fun I plugged in a 6A8 and the reception was noticeable better. I'll pick up a 6J8 from the radio club this weekend, that should give even better reception. The cathode has a 0.2 uf capacitor in parallel with a 150 ohm resistor going to ground, no coil.
Thank you so much for your great help!
How can 6A8, a pentagrid, plug instead of the other tubes, which are triod-heptodes?
Hi Roger,
First off, you're welcome!! Solving problems like these keeps my brain going.
I am stunned that the radio worked as you described with a 6J7 or 6K7, or even a 6A8. In a "Cathodyne" Oscillator Mixer, the oscillator circuit is from plate to cathode, leaving the grid for the RF signal input to be mixed with the oscillator frequency, thereby producing the IF Frequency at the plate. The "pentagrid" mixer used the cathode, first grid and the second grid (the "plate grid") as the oscillator, and the cathode, 4th grid and plate as the Mixer, mixing the RF signal with the oscillator signal. (The 3rd and 5 grids serve to isolate the oscillator from the mixer and are used as screen grids, connected to a positive voltage lower than B+).
The triode-heptode used the triode as the oscillator and the heptode as the mixer. Since the triode grid is connected to a grid in the heptode, I can maybe see the 6A8 working but the 6J7 or 6K7, with no feedback to the cathode? WOW!! Well, most agree that Philco builds a good radio.
Is the tube diagram in your radio a factory diagram or is it missing. If a factory diagram, was 6K7 printed in the same font as the label or handwritten? If no label, were the tube numbers stamped on the sockets? If so, maybe someone grabbed the wrong one during assembly. The folks who built these radios were skilled assemblers who worked from pictorial diagrams, not schematic diagrams. Knowledge of electronics was optional.
In the late 1980s, American companies were getting used to some Japanese practices. One of these was a "JIT" (Just In Time) supply chain. Philco was fairly big into car radios (as was Motorola) and the "Loctal" (Locking Octal) or "Loctail" (Locking tail, another name for Loctal) tube, invented by (I believe) Sylvania for Philco were basically designed for Car radios. Philco was an early proponent of using car radio tubes in their household radio. Philco was one of the first companies to use tubes with 6V filaments and indirectly heated cathodes, such as the 36, 38, 41, 77, 78, etc., with filaments designed for 6VDC operation in household radios, finding that these tubes worked just fine on 6VAC to the filaments. The 7J7 and 6J8 are very similar in function, even in internal connections, the only difference being Loctal vs Octal base and the pinouts. It seems that they would switch from one to the other depending on availability or what deal they could get. Philco advertised and sold their own tubes but they did not manufacture tubes. They were manufactured mostly by Sylvania, who also manufactured many of Zenith's tubes.
BTW, how is the audio when you use the Bluetooth?
Definitely write back to this thread with the outcome when you get the 6J8! I gotta know!
Best regards,
John, MrFixr55
@Morzh, Roger and anyone else interested- A 6A8? I am trying to figure out how a 6K7 (remote cutoff pentode) would work when a triode-heptode is called for. Pin 6 of the 6J8 is the oscillator plate. Pin 5 is the oscillator grid, also connected to grid 3 of the heptode (the oscillator signal output to the mixer?). On a 6A8, Pin 5 is G1 (the oscillator grid), pin 6 is G2 (the oscillator "Plate Grid). The 6A8 is not the correct tube to drop in for a 6J8, but at least it may oscillate, tune and mix, based on the connections to it (The RF input to the mixer is the grid cap in both tubes).
I have NO idea how a 6J7 or 6K7 pentode would work, as pin 6 of the radio (the 6J8 Triode Plate) has NO connection in a 6J7 or 6K7. Since that oscillator plate circuit contains the primary of the oscillator coil, having no connection means having no oscillator.
For all following this very interesting but wordy (my fault) thread, attached below is a link to the 1940 edition (RC-14) of the RCA Receiving Tube Manual, courtesy of the World Radio History website:
https://www.worldradiohistory.com/BOOKSH...14-OCR.pdf
The worldradiohistory.com website has many, many useful documents, from all revisions of the RCA Receiving Tube Manual to several of the RCA Victor "Red Books" plus so much on the history of radio. I urge all members to have copies of the RCA Receiving Tube manual, as it is very useful in getting the pinouts that may not be listed on schematics, to some rather good theory on the different types of tubes (diode vs triode vs tetrode vs pentode, etc.) I often cite the 1940 version (RC-14) of the RCA Receiving Tube Manual because it has the best descriptions of the tubes used in pre-war Philcos.
Since so many of these tube numbers sound so much like each other care (at least more care than i used at times) must be used in confirming the tube number. For example a 6J7 and 6K8 are VERY different tubes.
Hi Folks, apologies again. For al interested, especially Roger, please reread the entire thread as I had ade several connections to the post. Rojer, I think that the bottom line here is that your radio was built to use a 6J8 triode Heptode instead of a 7J7 triode Heptode or any other tube for that matter. Again, I can understand the possibility of a 6A8 or 6K8 possibly working, but a 6J7 or 6K7, I have no idea on how they would function as a convertor due to pin 6, an important connection, not existing on a 6J7 or 6K7.
Roger, I hope that you can get a 6J8, I GOTTA know how this Magillie (Mahguil?) ends.
