Model 19 (89) Chassis Washer Thickness
What is the correct thickness (new) for chassis washers for the model 19 (code 126) - I assume a model 19 chassis is almost the same as a Philco 89? It appears that the choices at http://www.renovatedradios.com/ are 7/8"d x 1/4"t, 7/8"d x 3/8"t, or 1"d x 1/4"t. It appears that the recesses in the cabinet will just accomodate 1" diameter washers, but 7/8"d could also be used.
But the thickness choices are 1/4" or 3/8", unless you guys know of another source. I just want the correct chassis height.
Thanks!
According to Mark Oppat at Old Radio Parts http://www.oldradioparts.net/rubber.html his part number PH-184 is correct for most 1930-1938 Philcos. These are 7/8 diameter by 3/8 thick.
I have successfully used both the 1/4 and 3/8 thick by 7/8 diameter on Philco 90's.
Ed
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 855 online users. [Complete List]
» 1 Member(s) | 854 Guest(s)
