Mikes, Sams, and Terry's Cabinet restoration chronicles
I have had these cabinet for way to long and this is the first spring I actually have some time to get these beauties rolling.
1. Philco 620 shouldered tombstone
2. AK 33 cabinet
3. Philco 503? combo unit
4. Philco Chairside 16RX
5. Zenith Toaster 6D525
6. AirKing model ?
Veneer chunks everywhere!
Repair time...
Show me how to fix the veneer chunks! I don't knew how to do a good job.
He had, a few years ago, a step by step veneer chunk missing repair thread.
Kirk's excellent tutorial lives here:
https://philcoradio.com/library/index.ph...-tutorial/
Oh No you can't start fixing it now (16RX) there's nobody to catch me when I faint!!!  Oh that's right I use to faint all the time and nobody caught
me.
Kidding aside Thanks!
Just don't pile them up together on top of other junk when hauling them in Kutztown Icon_lol
BTW....there's also that 16B.....with the scratch...or is there?
Dont fall Terry! BUT if you do can I have the check? Icon_lol
Yes Mike, it is in que to be fixed up. I want these done just as much as y'all do.
Veneering has begun.
Sams combo unit is most likely going to be re-veneered so I picked up a 4' x 8' sheet of strait grained Walnut.
I have repaired most all the chips and they are now going to be chiseled & sanded.
Mikes 620 cabinet is horrid. Everything is loose and separated. Must have been in a basement?? Every time I repair veneer that falls off another piece falls off.  Icon_mad
Icon_crazy
Excellent tutorial. Thanks!!
I wonder about the basement Icon_smile
Are you even sure ir is mine?
https://philcoradio.com/phorum/showthrea...hlight=620
It's been exactly 4 years.
I am not even sure the chassis works anymore. It could've died from cold without the cabinet.
Icon_lol
Wow
They are in bad shape. I would say do the best you can
But knowing you they will come out excellent
Is that my zenith?  Seen other one but the don’t have handle
Is it suppose to or not ?
Thanks kirk
Sam
Sam!
Were've you been?
Do you only pop up when Kirk restores your cabinets?
Sam, some of the Zenith "toaster" sets had handles and some did not..... good to hear from you again!
Icon_lol you a funny guy Mike.... Yes it is the only one I have. Things arent falling off but they are separated so I have to either rip them off and re-attach or inject where possible. No worries, She is going to be wonderful... Then she can warm up your chassis. Icon_wink
It's not that bad Sam and it is definitely worth restoring even with the issues. It is a rare set... Even I dont have one. Icon_evil
John is correct. This one came with the handle but many do not.... AND yes it is the one you bought at Kutztown in 2018.
Me...
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
