Threads: 4
City: Ottawa
State, Province, Country: Ontario
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
The cap is Mershon, generally 8mf but may have a section in some radios up to 18mf. I replace the entire cap with a vegetable can (so I have a platform for a terminals strip). One could install insulated feed through into the can and mount caps inside. In view that modern caps only have 5 yr life easy access for replacement is desirable.
Gutting the Mershon is a fool's folly as well as messy and serves no purpose other than to brag "yes I can, can"
If the chokes can be measured and are around 30hy, 2-4mf is fine. At that value metalized will be O.K. and have an unlimited life. In the 20's, accomplishing 4 mf in a paper cap was done with multiple .5 units
Mounting a perfboard or a double terminal strips with brackets will make for a neat repair. Arranging the cylindrical metallized in even, "cord-wood" rows..
As always, when suggesting:
YMMV...
Chas
Pliny the younger
Threads: 21
City: Wellborn Florida
Threads: 21
Did a search using France manufacturing corporation found Radio-Engineering-1926-12 as a PDF which is to big to post has lots of info on battery eliminators.
(This post was last modified: 07-28-2023, 07:25 PM by
David.)
Threads: 4
City: Ottawa
Thank you David. I too have been checking in radio literature and looking at
https://worldradiohistory.com in particular.
what i'm looking for now is anything on model M814 condensers by Mershon. I think it might mean 8 mfd total (2 mfd on each anode).
Thanks again.
Threads: 21
Threads: 21
(This post was last modified: 07-31-2023, 04:24 PM by
David.)
