11-15-2016, 12:04 AM
(11-14-2016, 09:25 PM)Mike L Wrote: Ok I'll give it a try. The few stations received are very very weak, So I feel there is something else going on too. I ordered a set of tubes to see if I might not have an issue there as well.
As far as using the signal generator is concerned, am I measuring output to the speaker with my VTVM? I have the alignment procedure, but It just states adjust for peak signal, but where? I'm also not 100% sure my SG is working properly either. With it connected to the grid cap of the det-osc tube, SG set at 460kc all I get is a low pitched squeal around the 460kc and 1000kc spots on the tuning dial. Nothing anywhere else.
Set radio dial at 550kc. Set sg dial at 460kc. Adjust #11 and 15 for max sound from spkr. Keep sg signal to a minimum as you adjust 11 and 15 for peak.
