11-11-2017, 07:49 PM
Hmmm.. Just did a bit more looking in to it and found that there are two different version of the 14 chassis. The 14B (table model) has the three 42 tubes. It has the 5900 ohm pri. The other version (floor and chairside models) has two 42 that are pentode connected. It takes an 12-14K transformer. Which do you have?
Before you get busy replacing the output transformer I'd check the driver transformer (if your set has three 42 tubes). This transformer can be difficult to source and expensive. Wouldn't proceed till I had a cabinet. My 2c.
Go here: http://philcoradio.com/phorum/showthread.php?tid=215 and open the spkr zip file. You can find all the specs for your spkr and transformer.
