anyone recognize this radio?
Hi murf,
That looks like an Ozarka V-16 to me. Does yours have a huge chassis with 16 tubes on it? (two rows of 8)
https://www.radiomuseum.org/r/ozarka_v16.html
A very rare radio. I think the number known to exist can be counted on two hands.
How long have you had it, that you haven't been able to ID it?
-Rodney
anyone recognize this radio? - by murf - 02-03-2018, 05:52 PM
RE: anyone recognize this radio? - by palegreenthumb - 02-04-2018, 12:31 AM
RE: anyone recognize this radio? - by Eliot Ness - 02-04-2018, 08:45 AM
RE: anyone recognize this radio? - by murf - 02-04-2018, 11:00 AM
RE: anyone recognize this radio? - by radiohenry - 02-04-2018, 11:01 AM
RE: anyone recognize this radio? - by murf - 02-04-2018, 01:27 PM
RE: anyone recognize this radio? - by rlongoria1 - 06-30-2019, 01:41 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5279 online users. [Complete List]
» 2 Member(s) | 5277 Guest(s)
