My first antique radio
Welcome to the phorum!!! You do know that you've started a vicious circle with that set. You'll probably spend more on vintage vinyl to play on it than you will spend on the set and refurbishing!! Enjoy!!! Take care, Gary
My first antique radio - by texan1325 - 11-15-2013, 05:39 PM
RE: My first antique radio - by klondike98 - 11-15-2013, 08:54 PM
RE: My first antique radio - by Arran - 11-15-2013, 09:41 PM
RE: My first antique radio - by texan1325 - 11-15-2013, 09:47 PM
RE: My first antique radio - by Jayce - 11-15-2013, 09:53 PM
RE: My first antique radio - by Eric Adams - 11-16-2013, 09:41 AM
RE: My first antique radio - by Jamie - 11-17-2013, 04:04 PM
RE: My first antique radio - by texan1325 - 11-17-2013, 06:14 PM
RE: My first antique radio - by Gene Pederson - 11-18-2013, 04:57 PM
RE: My first antique radio - by GarySP - 11-18-2013, 06:16 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2128 online users. [Complete List]
» 3 Member(s) | 2125 Guest(s)
