  • 1 Vote(s) - 5 Average
Fogged clear
I did a little research and it seems to be a decision by Penguin Paints who bought out Deft in 2013.
Fogged clear - by Eric Adams - 06-29-2014, 09:17 PM
RE: Fogged clear - by Steve Davis - 06-29-2014, 09:56 PM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 04:38 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 07:49 AM
RE: Fogged clear - by morzh - 06-30-2014, 07:57 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 08:01 AM
RE: Fogged clear - by morzh - 06-30-2014, 09:54 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 10:33 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 10:43 AM
RE: Fogged clear - by bfrohwein - 06-30-2014, 11:21 AM
RE: Fogged clear - by Steve Davis - 06-30-2014, 12:19 PM
RE: Fogged clear - by Chuck Schwark - 06-30-2014, 12:45 PM
RE: Fogged clear - by Bob Andersen - 06-30-2014, 08:22 PM
RE: Fogged clear - by jerryhawthorne - 06-30-2014, 09:48 PM
RE: Fogged clear - by TA Forbes - 07-01-2014, 12:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 01:13 PM
RE: Fogged clear - by Warren - 07-01-2014, 03:09 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 03:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 04:47 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 05:41 PM
RE: Fogged clear - by Arran - 07-01-2014, 11:09 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 11:56 PM
RE: Fogged clear - by jerryhawthorne - 07-02-2014, 12:05 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
