Philco 53-706 restoration Chronicles
Really Steve? With the cabinets you are making.....
I got around to coloring the cabinet. Just have to add the gold paint and put her back together. Oh wait, I didn't clear the cabinet yet, Icon_crazy
I can send the files to anyone who needs them with all specs.
RE: Philco 53-706 restoration Chronicles - by OldRestorer - 08-13-2014, 04:26 PM
RE: Philco 53-706 restoration Chronicles - by sam - 08-16-2014, 12:59 PM
RE: Philco 53-706 restoration Chronicles - by sam - 09-07-2014, 03:45 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5352 online users. [Complete List]
» 1 Member(s) | 5351 Guest(s)
