38-2670 cabinet problem
 Short of replacing the cracked veneer I think that any sort of repair you try is going to be temporary, it's too sharp of a bend and there is no enough purchase on the side of each crack towards the rear. This seems to be a common problem with sharp radius bends on Philco cabinets of the 1937-38 period. Since I don't have such a cabinet to examine I can only speculate that the cause may be in that they used some sort of solid structural wood under that veneer that expands enough to snap the veneer right across the grain. That being said it is also a very sharp bend on this cabinet, even sharper then the radius above the control panel of a 37-116.
38-2670 cabinet problem - by murf - 09-27-2014, 02:46 PM
RE: 37-675 cabinet problem - by sam - 09-27-2014, 03:25 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-27-2014, 07:51 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-28-2014, 02:07 PM
RE: 37-675 cabinet problem - by murf - 09-28-2014, 03:19 PM
RE: 38-2670 cabinet problem - by Arran - 09-30-2014, 08:47 PM
RE: 38-2670 cabinet problem - by murf - 10-01-2014, 07:02 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 05:18 PM
RE: 38-2670 cabinet problem - by Ron Ramirez - 10-03-2014, 05:37 PM
RE: 38-2670 cabinet problem - by PhilcoJohn - 10-03-2014, 06:25 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 08:31 PM
RE: 38-2670 cabinet problem - by Arran - 10-04-2014, 10:08 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-05-2014, 06:52 AM
RE: 38-2670 cabinet problem - by Arran - 10-07-2014, 10:43 PM
RE: 38-2670 cabinet problem - by murf - 10-08-2014, 12:32 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-08-2014, 11:38 PM
RE: 38-2670 cabinet problem - by murf - 10-26-2014, 02:01 PM
RE: 38-2670 cabinet problem - by sam - 10-26-2014, 02:29 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-26-2014, 02:36 PM
RE: 38-2670 cabinet problem - by klondike98 - 10-26-2014, 02:46 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-26-2014, 09:16 PM
RE: 38-2670 cabinet problem - by jerryhawthorne - 10-27-2014, 01:12 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5203 online users. [Complete List]
» 1 Member(s) | 5202 Guest(s)
