38-2670 cabinet problem
You can install veneer on a sharp radius horizontally by soaking it in veneer softener and using the cabinet as a form. Once dry you can trim and install it. They used steam in the old days......some cabinet makers still do although most use bending irons, heat blankets and vacuum forms. I'm sure there are other ways as well.
38-2670 cabinet problem - by murf - 09-27-2014, 02:46 PM
RE: 37-675 cabinet problem - by sam - 09-27-2014, 03:25 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-27-2014, 07:51 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-28-2014, 02:07 PM
RE: 37-675 cabinet problem - by murf - 09-28-2014, 03:19 PM
RE: 38-2670 cabinet problem - by Arran - 09-30-2014, 08:47 PM
RE: 38-2670 cabinet problem - by murf - 10-01-2014, 07:02 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 05:18 PM
RE: 38-2670 cabinet problem - by Ron Ramirez - 10-03-2014, 05:37 PM
RE: 38-2670 cabinet problem - by PhilcoJohn - 10-03-2014, 06:25 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 08:31 PM
RE: 38-2670 cabinet problem - by Arran - 10-04-2014, 10:08 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-05-2014, 06:52 AM
RE: 38-2670 cabinet problem - by Arran - 10-07-2014, 10:43 PM
RE: 38-2670 cabinet problem - by murf - 10-08-2014, 12:32 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-08-2014, 11:38 PM
RE: 38-2670 cabinet problem - by murf - 10-26-2014, 02:01 PM
RE: 38-2670 cabinet problem - by sam - 10-26-2014, 02:29 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-26-2014, 02:36 PM
RE: 38-2670 cabinet problem - by klondike98 - 10-26-2014, 02:46 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-26-2014, 09:16 PM
RE: 38-2670 cabinet problem - by jerryhawthorne - 10-27-2014, 01:12 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5300 online users. [Complete List]
» 2 Member(s) | 5298 Guest(s)
