38-2670 cabinet problem
Ok,
Here is the finished cabinet guy's.[Image: http://i1161.photobucket.com/albums/q509...abinet.jpg]
38-2670 cabinet problem - by murf - 09-27-2014, 02:46 PM
RE: 37-675 cabinet problem - by sam - 09-27-2014, 03:25 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-27-2014, 07:51 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-28-2014, 02:07 PM
RE: 37-675 cabinet problem - by murf - 09-28-2014, 03:19 PM
RE: 38-2670 cabinet problem - by Arran - 09-30-2014, 08:47 PM
RE: 38-2670 cabinet problem - by murf - 10-01-2014, 07:02 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 05:18 PM
RE: 38-2670 cabinet problem - by Ron Ramirez - 10-03-2014, 05:37 PM
RE: 38-2670 cabinet problem - by PhilcoJohn - 10-03-2014, 06:25 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 08:31 PM
RE: 38-2670 cabinet problem - by Arran - 10-04-2014, 10:08 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-05-2014, 06:52 AM
RE: 38-2670 cabinet problem - by Arran - 10-07-2014, 10:43 PM
RE: 38-2670 cabinet problem - by murf - 10-08-2014, 12:32 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-08-2014, 11:38 PM
RE: 38-2670 cabinet problem - by murf - 10-26-2014, 02:01 PM
RE: 38-2670 cabinet problem - by sam - 10-26-2014, 02:29 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-26-2014, 02:36 PM
RE: 38-2670 cabinet problem - by klondike98 - 10-26-2014, 02:46 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-26-2014, 09:16 PM
RE: 38-2670 cabinet problem - by jerryhawthorne - 10-27-2014, 01:12 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2178 online users. [Complete List]
» 3 Member(s) | 2175 Guest(s)
