Threads: 11
City: Castro Valley, CA
Hi, Folks. I'm back with another request for assistance. Recently, I purchased a 59s for $5 and did the recap, replaced the resistors, and rewound the coils for practice. When I fired it up, there was no sound. Before I take voltage readings (I have to get a battery for my multimeter), do any of you have suggestions or tips?
Here is a link to the schematic:
http://www.nostalgiaair.org/pagesbymodel...013790.pdf
Thanks in advance.
Dave
Threads: 530
City: Jackson, NJ
It goes against my convictions to recommend doing anything before you could look at voltages and test the tubes.
I don't like blind troubleshooting.
Even if I told you to check the speaker (and I don't) - it requires a working meter.
(This post was last modified: 07-13-2016, 09:50 PM by
morzh.)
Threads: 266
+1
Looks like a scrunched up model 84. You know real voltmeters don't use batteries.
Threads: 530
City: Jackson, NJ
(07-13-2016, 09:33 PM)Radioroslyn Wrote: +1
Indeed, looks like the 80jr regen.
Threads: 11
Good news, sort of. One of the tubes wasn't seated properly so now the radio hums and hums loudly when I touch the top of the 77 second detector tube. Sounds like a start.
I will get a real voltmeter.
Threads: 266
At this point you can try putting a 460kc signal to the cap of the 77 closest to the front panel. Adjust #8 and 15 for max signal from spkr.
