Philco ventilator
Picked it up a few days ago its in pretty good shape for its age ..motor mount was not rotted away like most seem to be ..Motor itself is getting a going over new bushings and had the rotor sanded and repainted (waiting for it to get back .
rear view
so far so good
got the waterslide decals from a fella at the antique fan collectors site
motor has bad bushings and caused the rotor to rub the stator ..but it is repairable ..new bushing being made .
an add from 1941
Very cool!
Well I'll be dipped in doggie doo!!!
That thing is NEAT.
Howard - EXCELLENT pictures and posts. Icon_thumbup This is great info, and perfectly illustrates the concept of "teaching with your posts."
That is BEAUTIFUL restoration work!
this PDf looks to be a later version of mine, that i assume was never put into production ..the rear door slides up and down instead of open and close . it also has a rear hood . iv wondered if it had any hardware that came with it ...i think it might have had a sash also .
rotor before giving it a good sanding with 220 grit .
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2109 online users. [Complete List]
» 3 Member(s) | 2106 Guest(s)
