philco transitone tropic model 3010-123 schematic
Yes, it was nice of Philco to not reveal the value of that resistor, wasn't it? Icon_thumbdown
Using Ohm's law, we will have to calculate it.
The five tube filaments in series will drop 101.5 volts.
The radio was, most likely, designed for a 115 volt line.
Each tube filament draws 0.15 A of current. As the filaments are in series, the entire string draws 0.15 A of current.
So the original resistor would have had to drop 13.5 volts.
R = E / I
= 13.5 / 0.15
= 90 ohms
Now we have to figure wattage.
P = I squared * R
= (0.15 x 0.15) 90
= 0.0225 x 90
= 2.025 watts
In practice, we normally double the wattage dissipation, so you need a 90 ohm, 5 watt resistor.
But hold on. If the line voltage where you are at is 240 volts, then does your radio have the extra dropping resistor plugged into the J1 socket?
