Philco 37-650 and 70 chassis washers
Can anyone recommend a vendor for the chassis washers of these two Philcos models, whom will not charge $4.00 a washer.
Yep. Lowes or Home Depot. You could buy their grommets and trim them. If this is what you want to do.
Trying to finish this 37-650 and after several weeks of not working on it, I am not receiving any stations lower than 710 AM. Tried to start alignment and found AC signal just above 200 volts A/C. Procedure indicates meter should be in the 30 volt range. I have the positive on the plate of one of the audio amp tubes and negative on cathode. Any suggestions as to could be the problem. I don't get ay meter swing when adjusting comparators neither. Thanks
I am not sure how you could get 200V AC across the output tuve, but myself, I always clip my meter to the output xfmr secondary (or speaker's voice coil) and measure volts.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
