Philco Model 90 volume pot value
Hey fellas -
Continuing a battle with a Model 90 w/single 47 tube version.  There's audible audio when turned all the way down plus some strange crackling after 10-15 minutes of use.   Volume pot part #5366 does not list a value and haven't been able to locate it.  I'm suspecting this one might be bad and have a spare.  The current pot measures 676k while the spare measures 215k.
1/2 meg.
Hello Paul,
One thing I would check is disconnect that volume control and hook an meter on it to
check how smooth the volume resistance changes and if you have one an old analog meter like my Simpson 260 works well for this !
Thank you Terry and Richard.  I also happen to have a Simpson 260 and will test.
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 2114 online users. [Complete List]
» 3 Member(s) | 2111 Guest(s)
