Finally found one (locally)
I have an H-13 speaker that should work with your set. Output xfrmr is bad but field coil/voice coil are good. Cone intact, has couple of minor tears, easy fix.
You will have to drill out the rivets and remove the old output xfrmr and replace it with yours. CAREFUL... cone is directly under rivets.
PM me with your address. We can work out the details later.
