Philco 38-5 veneer issues, what is this wood?
I have done several threads on veneer replacement, one not to long ago on a Philco 650PX. It will show a lot of what you ask, also done a thread on a 1936 Wurlitzer juke box veneer on whole cabinet with rounded sides. Ron could find them in archives and tag them that you can open thread.
Fred, I have a better idea:
You find them and post links.
Icon_smile
You can do a search for your own posts, or search by username "Frederick W. Taylor".
http://philcoradio.com/phorum/search.php
 It's plain cut French walnut I believe. But since some of the veneer is damaged and is scrap anyhow you could use it for gluing experiments.
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
