Philco 42-350 dial lamp question
Just started work on a beautiful pristine condition 42-350 and was wondering if anyone knew which pilot lamp bulbs I can replace with.
There are 2 (one on each end of the dial glass) that have on markings - etched or stamped.
There is one in a cardboard sleeve on the assembly that clicks up and down and supposedly lights up which band you have selected on the dial. That one has .25A 6.8V stamped on it.
2 of the 3 are burned out.
They are all bayonet style and look like #44s or #47s but I would like to replace with as close as possible.
The parts list and schematic I got off Riders doesn't have that data.
Any suggestions?
You can find the Philco service info in the Library:
https://philcoradio.com/library/index.ph...year-book/
It says the dial and indicator lamps are Philco part 34-2064.
Looking at the Library parts reference:
https://philcoradio.com/library/index.php/parts/lamps/
That maps to an equivalent #44 bulb.
Thanks.
I have plenty of #44s so I will just swap out all 3 bulbs and be done with it.
Hello again;   I found a model 838 car radio on Nostalgia Air under United American Bosch, http://www.nostalgiaair.org/...Arran — 09:32 PM
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
There are currently 4040 online users. [Complete List]
» 1 Member(s) | 4039 Guest(s)
