Wood Type Used
Need to make a few of them wood patterns,,,maybe for other people on line ,,MAYBE ??? CHEERS
That looks like luann plywood, otherwise known as "Philippine Mahogany", which is not even close to being a real mahogany. I think that the original grille had some tulip poplar veneer on it, and may have been poplar all the way through, it has a grain very similar to the unfinished part. The luann ply is very frustrating to cut cleanly, it is soft and chips all over the place.
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
Hello Dan, That really turned out very nice and I also like that color it is not to dark . I Have General Electric m...radiorich — 08:50 PM
Table radio 51C or 52C?
The model 51 and 52 are identical mechanically, I'm not sure what may have been changed between the two chassis but one ...Arran — 08:18 PM
Well today I  installed the grill cloth board and the speaker.  The speaker must weigh 20 pounds by itself. I put the c...Dan Walker — 08:10 PM
Unidentified Philco Bakelite
It's a British Philco, likely from the early 1950s. It has a very common layout for British sets starting in the post wa...Arran — 08:02 PM
I suggest you take that look under the hood eventually. Makes little sense to try to figure things out without looking ...morzh — 07:03 PM
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM
Morzh There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM
There are currently 281 online users. [Complete List]
» 1 Member(s) | 280 Guest(s)
