Philco k-6
I’m looking for the specifications for the Philco K-6 speaker field coil Looks like I’m going to have to use a permanent magnet speaker I can’t seem to find a K-6 speaker
Benny
benny
go to philco files for free down load      http://philcoradio.com/phorum/showthread.php?tid=215
scroll down to attached files  down load speaker zip
look  at line 86
sam
Hi Benny,
According to Philco Service Bulletin #180-A, the K-6 (which is also listed as a replacement for the K-5) has the following specs:
-Field coil resistance 3275 ohms D.C.
-Voice coil resistance 1.1 ohms D.C.
-Output transformer primary resistance 680 ohms D.C.
You could use a K-2 from an early 90 (2-45),not an exact match electrically but close enough.
M R Radios   C M Tubes
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1026 online users. [Complete List]
» 2 Member(s) | 1024 Guest(s)
