Philco 42-350 dial lamp question
Just started work on a beautiful pristine condition 42-350 and was wondering if anyone knew which pilot lamp bulbs I can replace with.
There are 2 (one on each end of the dial glass) that have on markings - etched or stamped.
There is one in a cardboard sleeve on the assembly that clicks up and down and supposedly lights up which band you have selected on the dial. That one has .25A 6.8V stamped on it.
2 of the 3 are burned out.
They are all bayonet style and look like #44s or #47s but I would like to replace with as close as possible.
The parts list and schematic I got off Riders doesn't have that data.
Any suggestions?
You can find the Philco service info in the Library:
https://philcoradio.com/library/index.ph...year-book/
It says the dial and indicator lamps are Philco part 34-2064.
Looking at the Library parts reference:
https://philcoradio.com/library/index.php/parts/lamps/
That maps to an equivalent #44 bulb.
Thanks.
I have plenty of #44s so I will just swap out all 3 bulbs and be done with it.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1018 online users. [Complete List]
» 1 Member(s) | 1017 Guest(s)
