How do I tell a which version 91 Cathedral I have?
I got this the other day, and I am driving myself nuts trying to figure out which version this is 91A, 91B ???? I am clueless can anyone help???
Thanks
Rock
(04-19-2012, 03:21 PM)rocklandman Wrote:  I got this the other day, and I am driving myself nuts trying to figure out which version this is 91A, 91B ???? I am clueless can anyone help???
Thanks
Rock
The tag says it all. You have a U.S. Philco Model 91, Code 123.
The B stands for Baby Grand. See Ron's site here for cabinet designations: http://philcoradio.com/tech/letters.htm
By the way, if you had a Model 91A, it would say A on the tag and it would also be a Canadian version and would also indicate this as well.
Basically the power transformer is different, due to power differences back then in Canada. 25Hz instead of 60Hz mainly.
Chuck
WOW!!! Thank you Chuck!!
Thanks
Rock
Chuck
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1118 online users. [Complete List]
» 2 Member(s) | 1116 Guest(s)
