Resistor values question
Do you have a meter? Can you buzz it to the switch?
I am on my phone so can't add pic. Radios is working well now. Only thing is that when I hook up the antenna to the cabinet I get no reception? If I remove it and hold the antenna wire, I get recption. The cabinet is supposed to be the antenna so I don't know what is going on.
Any ideas?
Kirk
Hi Kirk
No don't think the case is connected to the ant. But the ant does connect to a 250mmfd mica capacitor. It will be about 3/4" square and have 3 colored dots, red,(=2) green(=5) and brown (=1 zero) 250.  Hope this helps.
Looking forward to seeing you in May
ps. your off/on switch might be in the coin box you don't have. Perhaps that's why you can't find it.
Common can negative means that the 3 filter condensers have - side connected together. Now on sets without a power transformer AC/DC sets. Sets with a voltage doubler (will only work properly with AC input to the power supply) and sets with a phono motor are not truly AC/DC sets.
One side of the AC line is connected the plate of the rectifier tube like a 35Z5, 35Y5, and 35W4. The other side the AC line is B- or where the - side of the filters would connect.
Now there is a problem if you connect B- to the chassis then you create a shock hazard. One side of the AC connected to the chassis could put 110vac between the radio chassis or the radio's metal cabinet and any thing that is grounded. So what they did is they took all of the parts that needed to be at B- and connected them together but NOT to the chassis. This creates a - buss. This is why your filter condensers - don't connect to the chassis.
Clear as mud right????
Ok,
My radio is 100% complete with the mech. The coin mech is its own switch where by putting in the quarter closes the switch giving power to the chassis. There is also a on/off volume pot on the chassis. I grounded all the negatives to the can since that is what was done originally and with these Tradios there was no antenna. There is a short wire with a washer on the other end that gets screwed right to the metal cabinet. All of the others I have worked on have this also.
I am thinking that maybe something is touching somewhere under the chassis. I just cant understand why this radio had good reception being attached to the cabinet before I re-capped it but now it doesnt???
Hmmmmmmmmmmm
It'll be good to see you too Terry
Well I figured it out. The chassis was grounding to the cabinet so I put in a few rubber washers and now she is working good!!
This is for my uncle so I'm glad it won't explode Icon_lol
Kirk
I take it then your uncle is not rich....Icon_lol
I have a red red brown resistor. It tests at 3.7 when the meter is on 200 ohm, the new resister doesn't even test on 200 ohm but it tests 2.2 when the meter is on 2k. They are the same color code so what am I doing wrong? Is the resistor just dead?
Thanks
Kirk
Try a control sample, a known good resistor of the same value bought recently. See how it behaves during test.
Oops it is red red brown. The second one is new.
Kirk
This just exploded so I  need to replace it. Is it a 100 mmfd cap? Meaning .0001?
Kirk
Looks like it's 2 o ooo @3oov But some of those postage stamp cap are screwy to decode.
I left my little oarfin Annie decoder ring at work today
So Kirk I'm getting a little peeved will you! YOU HAVEN'T INVITED ME UP TO YOUR NEW PLACE!
I mean I was thinking you could put out your 50 worst chassis and we could knock them out in a few hours
But no invitey no fixy Beside I have something warm and fuzzy for you.
ps The problem with measuring the 220 ohm resistor is when you set your meter for 200 ohms it can't
measure any thing above 200 ohms. When you set your meter for the next higher range it can measure it.
So it is .0002?
You are welcome any time and you know it.
I figured I would wait on having guests until I actually live there.
I had the meter on the higher setting for both tests.
Kirk
What did this cap come out of ?  Is there a schematic  online for it?? Just want to double check to be sure.
Shoot an email at: tbs50a@aol.com Busy this weekend next is open.
I believe this is it. line up matches.
http://www.nostalgiaair.org/PagesByModel...021845.pdf
Kirk
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
There are currently 900 online users. [Complete List]
» 1 Member(s) | 899 Guest(s)
