Threads: 4
City: Freeport, LI, NY
Hi Guys......
On the bench is a model 96 and I'm having a few issues....
Is there a list for the resistor values? Other than part numbers and Bintliff's Philco Cap Guide Pt. II, I was just wondering if a Philco list can be found.
Can someone furnish me with the resistance value of the field coil? Mine's reading about 2,200 ohms DC. On a test, I had 334 VDC going into the FC and 150 VDC coming out. It should be about 225 VDC. Monitoring the amp draw of the radio, it's around 800 ma. I think this coil is shorted but knowing the actual resistance value would be a big help. (the cap can (p/n 3754) has been recapped and works fine.
Tnx...
...Jim
Threads: 573
Go to the sch section here at Philcoradio, open 96 sch, it has all resistors.
2,200 ohm looks right, also the values of field coils are not likely to change, it is either right value, or open, rarely short.
Threads: 4
(07-01-2015, 03:01 PM)morzh Wrote: Go to the sch section here at Philcoradio, open 96 sch, it has all resistors.
Where's the schematic section?
Threads: 573
Threads: 268
When I look at the diagram the output of the p/s goes into the FC then the other side of the FC goes to #45 to ground. I think what you are seeing is the voltage drop across the FC+#45. That not to say that you could have a bad filter cap or any of the bypass caps w/the resistors inside. Always use mylar cap to replace the filters
Threads: 573
Jim
1. A shorted coil would give you MORE voltage at the output, not less.
2. A shorted coil would not be 2,200 Ohms.
3. What you have is an excessive draw by the load. Have you recapped your radio? What else have you checked so far?
Threads: 18
Agree, if there was any intermittant in field coil to frame (which is probably ground potential,) could draw current. Check the coil out of circuit to probably prove innocent or otherwise.
The original Philco speaker field was 3,200 ohms.
Threads: 268
Don't think the spkr frame is at ground potential. Just has 4 wires for the FC and OPT. This mounted to the wood cabinet. Did you measure the FC resistance with the spkr unplugged from the chassis?
(This post was last modified: 07-01-2015, 08:37 PM by Radioroslyn.)
Threads: 4
Hi Guys...
Ron's number seems to prove out that the FC is shorted. I'm reading 2,200 ohms DC. Together with the open primary on the OPT, the main problem is right here. The FC can be taken out of the speaker fairly easily so I think I'll rewind it.
Anyone know of a rewinding shop on the East Coast?....or have another Model 96 speaker they can spare?
Again Tnx....
...Jim
(This post was last modified: 07-02-2015, 10:16 AM by Jim Koehler.)
Here is a list of resources found in our online library that you might find useful. Mike's Gobs of Knobs email addres...klondike98 — 01:46 PM |
First Radio restoration
Hi Tubeman,
Welcome to the Philco Phorum. Phamily Phriendly Pfun with Phine Pholks Phull of Philco Phacts. (See a p...MrFixr55 — 12:33 PM |
You could post in the WANTED ADs section here on the Phorum and see if anyone has an RF generator that they want to sell...klondike98 — 11:55 AM |
Good ideas, thank you Arrange and Rich. I have the adhesive aluminum foil already and can try that immediately.
More ...EdHolland — 10:18 AM |
Murf;
I found this thread on the ARF, the first photo has a pretty good view of the dial glass.
ArranArran — 01:12 AM |
hello Ed,
how about that speacial tape used for ducting it's like foil or how about thin piece of
aluminum roof flash...radiorich — 12:19 AM |
Ed;
One material that I have seen, but never tried for this was material for making exhaust gaskets, it's similar to ...Arran — 11:42 PM |
I just remembered, I have some hi temp silicone rubber material which could do the trick. Or a piece of FR4 laminate. Th...EdHolland — 08:39 PM |
The PSU filter cap arrived today (thank you USPS!) so I will work on that later.
Meanwhile, I have the dial, speaker...EdHolland — 06:42 PM |
Thanks Terry. After checking my notes I think I recorded about -10v at the 6A7 G4/control grid. The screen grid (G3 &...Tubester — 05:59 PM |
There are currently 1497 online users. [Complete List] » 3 Member(s) | 1494 Guest(s)
