38-12 dial lamp antenna?
Lightbulb
This is weird!
Got a 38-12 on the bench, and there is a dial lamp socket wired between the antenna coil and ground,
with red and green wire about a foot long between the socket and the set, I wouldn't even be posting this
except the wire on the socket and solder connections in the set look virgin.
anyone see an antenna connection that is a dial lamp socket?
Weird, yea!
Keith
Can't say that I ever have. Does it light up???
(11-18-2015, 12:48 PM)Radioroslyn Wrote:  Can't say that I ever have. Does it light up???
I cant imagine it does, except maybe briefly when lightening hits nearby. There was no bulb in the
socket.  I think Ill leave it on, make a screw base for an antenna and have it as a conversation piece
when I sell it.  Part of the radio's history!
Keith
Well, by the time lightning got to the little bulb, even CSI Crime Lab couldn't find it, anyone remember "Lightning Arrestors?"
Shadow Meter Bulb
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
