Threads: 4
City: Freeport, LI, NY
Hi Guys......
On the bench is a model 96 and I'm having a few issues....
Is there a list for the resistor values? Other than part numbers and Bintliff's Philco Cap Guide Pt. II, I was just wondering if a Philco list can be found.
Can someone furnish me with the resistance value of the field coil? Mine's reading about 2,200 ohms DC. On a test, I had 334 VDC going into the FC and 150 VDC coming out. It should be about 225 VDC. Monitoring the amp draw of the radio, it's around 800 ma. I think this coil is shorted but knowing the actual resistance value would be a big help. (the cap can (p/n 3754) has been recapped and works fine.
Tnx...
...Jim
Go to the sch section here at Philcoradio, open 96 sch, it has all resistors.
2,200 ohm looks right, also the values of field coils are not likely to change, it is either right value, or open, rarely short.
Threads: 4
(07-01-2015, 02:01 PM)morzh Wrote: Go to the sch section here at Philcoradio, open 96 sch, it has all resistors.
Where's the schematic section?
When I look at the diagram the output of the p/s goes into the FC then the other side of the FC goes to #45 to ground. I think what you are seeing is the voltage drop across the FC+#45. That not to say that you could have a bad filter cap or any of the bypass caps w/the resistors inside. Always use mylar cap to replace the filters
Jim
1. A shorted coil would give you MORE voltage at the output, not less.
2. A shorted coil would not be 2,200 Ohms.
3. What you have is an excessive draw by the load. Have you recapped your radio? What else have you checked so far?
(This post was last modified: 07-01-2015, 03:46 PM by morzh.)
Threads: 18
Agree, if there was any intermittant in field coil to frame (which is probably ground potential,) could draw current. Check the coil out of circuit to probably prove innocent or otherwise.
The original Philco speaker field was 3,200 ohms.
Don't think the spkr frame is at ground potential. Just has 4 wires for the FC and OPT. This mounted to the wood cabinet. Did you measure the FC resistance with the spkr unplugged from the chassis?
(This post was last modified: 07-01-2015, 07:37 PM by Radioroslyn.)
Threads: 4
Hi Guys...
Ron's number seems to prove out that the FC is shorted. I'm reading 2,200 ohms DC. Together with the open primary on the OPT, the main problem is right here. The FC can be taken out of the speaker fairly easily so I think I'll rewind it.
Anyone know of a rewinding shop on the East Coast?....or have another Model 96 speaker they can spare?
Again Tnx....
...Jim
(This post was last modified: 07-02-2015, 09:16 AM by Jim Koehler.)
